I've been having a bit of trouble with a relatively simple power factor correction problem involving a simple circuit in the frequency domain (\$f=50\,\text{Hz},\omega=2\pi f=100\pi\,\text{rad/s}\$).
From what I can tell, my first step is to determine the complex power \$S=V_{eff}I_{eff}^*=\frac{V_{eff}V_{eff}^*}{Z_{eff}^*}=\frac{|V_{eff}|^2}{Z_{eff}^*}\$ consumed by the circuit in its current state (without the corrective capacitor), in which case I figured the total impedance should be \$Z=-j10\,\Omega+\dfrac1{\dfrac1{20\,\Omega}+\dfrac1{j20\,\Omega+10\,\Omega}}\approx11.435\angle{-19.653^\circ}\,\Omega\$.
However, this strikes me as quite odd; \$\arg S=\arg Z<0\$ suggests that the power is lagging and therefore (intuitively) the power factor cannot be 'corrected' with the use of another capacitor (negative reactance), requiring instead an inductor (positive reactance).
In fact, when trying to solve this problem, I found two results -- both giving positive reactances \$X_C=-j\frac1{\omega C}\$ and thus 'negative' capacitances. This is nonsensical, no? Have I computed the total impedance incorrectly?
Thanks.
