as "Andy aka" already wrote you've tried to break the GBW limit of an operational amplifier and didn't got the gain you've expected. For your application you need an OpAmp with a GBW of roughly 700Mhz.
Well, those exist. They aren't cheap and due to their high frequency they are very picky about PCB layout.
Fortunately a different kind of OpAmps exist that don't tie gain and band-width together. These are called "Current Feedback OpAmps". They have different characteristics than the ordinary "Voltage Feedback OpAmps". They can't do all the things your Voltage Feedback OpAmps can, and they have some hard restrictions about what you can put into the feedback path of the OpAmp, but for amplification jobs they might be an alternative choice for you.
One specimen of that class that I have made very good experience with is the LT1227 OpAmp. It has a transit frequency of 140Mhz regardless of gain (within reason of course). You can even buy it in DIP8 package if you're using through hole parts for prototyping. And they are available and not that expensive.
Ultra Short Prime on Current Feedback OpAmps:
The CFA is very picky about what happens in it's feedback path, e.g. the components you put between it's output and it's inverting input. Different parts have different requirements, but generalized you'll end up with a fixed, relative low resistor. For the LT1227 that is 1kOhm.
You must never put a capacitor in the feedback-loop, so all integrator circuits and some filter circuits are not possible to realize.
The positive and negative input have very different characteristics. While the positive input terminal is high impedance like in a good Current Feedback OpAMp, the negative input is usually low impedance. Also the inputs aren't matched at all.
In your application you want an inverting amplifier. This is not ideal for a CFA, but works. Since the feedback resistor is fixed at 1KOhm, your input resistor will be 50Ohm, so you end up with an input impedance of roughly 1KOhm. That's not much, but may work for you.
If you can change your circuit to the non-inverting configuration the input impedance restriction will not be a problem.
TL;DR: It is worth looking into Current Feedback OpAmps if you want high gain with high bandwidth and don't plan to do anything fancy except amplification.
