I'm trying to use a 12 volt WiFi relay setup to control a 12 volt DC motor. The WiFi relay has eight 10 A SPDT relays in it and the motor is 15 A. I understand how to wire it directly to the two relays that are in the box, but I'm lost after that. Here are my questions:
Since I'm using two 10 A relays at the same time to control the motor (positive through one and ground through the other), does this mean that I have a 20 A capacity with the relays?
How else could I wire this up to increase the relay capacity (or run the signals from the WiFi relays) to other relays and protect the WiFi relay box?
Here's the info on the WiFi relay:
