Need some help with the connections of the potentiometer.
In the circuit example provided in the link, I'm connecting the potentiometer as a voltage divider and not a variable resistor right? So instead of just connecting 2 pins, the Vcc pin of the potentiometer is connected to pin 16 of the sg3525 chip, Gnd pin of the potentiometer to Gnd and the middle pin or output is connected to pin 2 of the sg3525 chip? Am I right about this?
Thanks.
