I have taken apart some circuitry that no longer works and I accidentally went a bit too far with the dremel. This means I've partially obscured the serial number of a component i'm wishing to identify.
There's 3 lines of text as far as I can see on the component in the centre.
- The 1st being (I think) EL1738
- 2nd NY135 (maybe)
- 3rd SSU
I've tried punching these into google without much luck.
The device itself switches on a coil every other time a hall effect sensor is triggered. My first thoughts are that this might be some sort of flip flop.
What id like to know is what else can I do in order to identify this component?
