My application has a bog-standard count-until-a-certain-number-then-reset-the-counter section. My experienced friend tells me that when using actual chips, it's common to increment the counter on the rising edge of the clock and reset the counter on the falling edge. That way the designer has a lot of time to do what needs to be done before the next clock arrives.
But he's never used a CPLD and I wonder if this changes the rules. Or if his information is technically sensible but not practically needed.
My design has something like
always @(posedge clock) begin (increment the clock) end
always @(negedge clock) begin (reset the counter conditionally) end
I'm not trained at all in electrical engineering, I just read and dabble. But I can't let it rest when I don't feel I have a certain (n00b-level) understanding of what's going on.
I just read an example from a university course where the instructor didn't care about when the counter was reset. His design was something like:
counter = counter + 1;
if (counter == some_number) counter = 0;
end
This leads me to believe I'm over-engineering, the instructor is instructing not building an industrial app, or the synthesis process handles such things.
Of course I could try it in the simulator or actually plop it into the CPLD. Eventually this is going to be driving a powerful machine and it's got to work every time. I can't have an edge case where the machine misbehaves.
EDIT - more context. While it may not matter with respect to the answer, I am counting pulses generated by an encoder attached to a rotating spindle. I have to count every one of them, and I can't lose any.
EDIT 2 - example of a loop that increments a counter, then on some condition, changes it.
module slow_count(
input clk,
output reg [3:0] count
reg[19:0] snooze = 0;
always @(posedge clk) begin
snooze = snooze + 1; // Set the counter
if (snooze == 1000000) begin
snooze = 0; // And change it here
count = count + 1;
if (count == 10) count = 0;
end
end
endmodule
some_number
is 27. Your instructors codes says, on each clock cycle, first increment the counter, then check if it's equal to 27, and change it, again, if it is. But there's no way to do that in CPLD hardware. What you need to do is check if the old value is 26, and use that to choose whether to make the new value be 0 orcounter+1
. \$\endgroup\$
