I came across the following slide on power combiner circuit and I have questions about it.
Why traverse across the upper half circle ?
Why "ZT-line is the geometric mean of Zout and Zin." ?
When translating an impedance towards the generator we move clockwise around the chart.
When translating an impedance towards the load, we move counter-clockwise around the chart.
This is a design decision that was made to get the desired result. If you choose a different \$Z_T\$, you won't get the equivalent load (\$Z_T\$ line plus actual load) to match your input impedance.
Notice how they overlaid the Smith chart scaled for \$Z_T\$ on top of the \$Z_0\$ Smith chart. You need to be able to rotate the load around from the 0-ohm point to the \$\infty\$-ohm point on the \$Z_T\$ Smith chart and have that end up being the correct place on the \$Z_0\$ Smith chart. That only happens if you choose \$Z_T=\sqrt{Z_{out} Z_{in}}\$
Traverse is across the upper half of a circle is because of adding physical line with length θ=90° delays reflection from Г(Zout) by 2*θ=180° (90° before reflection and 90° after reflection). On a Smith chart phase delay corresponds to clockwise rotation around some center depending on Zline(phase decreases clockwise). Cutting physical line length will result in counter-clockwise direction. Rotation go through upper or lower half circle depending on particular values of Zout and quarterwave transformer line impedance Zt.
Maybe for emphasizing that it is not an arithmetic mean (Zout+Zin)/2.
Formula for Zt is derived without using Smith chart. Smith chart is a graphical aid.
Why overlay the Smith chart scaled for ZT on top of the Z0 Smith chart?
Maybe it is more convenient to use Z0=Zt Smith chart for obtaining impedance transformation graphically without formulas (Smith chart center at Zt, not at 50 Ohm)
For deeper understanding of Smith chart I recommend to calculate impedance change for different line lengths using formulas, then calculate corresponding reflection coefficient Г (vector) for each case and draw it on a Smith chart.
