It'd be of great use for us to emit correct rule check violations for power pins in IC we use. The logic is to force compiling failure when power pins of ICs are not driven correctly from power sources.
When we used KiCad Power pin could have been in or out hence when PowerIn pins where not connected to PowerOut pin an ERC error was emitted, but with Altium designer we only have Power Pin without direction.
The only violation on the matter is when input pins are not driven by output or power pin.
The only workaround we thought of is changing our ICs power pin to input pins, but we would really like to avoid that.
Are we missing something?
P.S. The hypothesis is of course that the violations are correctly signalled through project preferences in connection matrix and in error reporting tabs
