i have atxmega256A3u with external 16Mhz crystal, i set the system clock to use that oscillator source as
uint8_t n,s;
    OSC.XOSCCTRL = OSC_FRQRANGE_12TO16_gc        /* 12 - 16 MHz */
    | 0 << OSC_X32KLPM_bp         /* 32.768 kHz XTAL OSC Low-power Mode: disabled */
    | 0 << OSC_XOSCPWR_bp         /* Crystal Oscillator Drive: disabled */
    | OSC_XOSCSEL_XTAL_16KCLK_gc; /* 0.4-16 MHz XTAL - 16K CLK */
    OSC.CTRL|=OSC_XOSCEN_bm;
    n=(CLK.PSCTRL & (~(CLK_PSADIV_gm | CLK_PSBCDIV1_bm | CLK_PSBCDIV0_bm))) |
    CLK_PSADIV_1_gc | CLK_PSBCDIV_1_1_gc;
    CCP=CCP_IOREG_gc;
    CLK.PSCTRL=n;
    // Wait for the Oscillators to be stable
    while (!(OSC.STATUS & OSC_XOSCRDY_bm));
    n=(CLK.CTRL & (~CLK_SCLKSEL_gm)) | CLK_SCLKSEL_XOSC_gc;
    CCP=CCP_IOREG_gc;
    CLK.CTRL=n;
    OSC.CTRL&= ~(OSC_RC2MEN_bm | OSC_RC32MEN_bm | OSC_RC32KEN_bm | OSC_PLLEN_bm);
    PORTCFG.CLKEVOUT=(PORTCFG.CLKEVOUT & (~PORTCFG_CLKOUT_gm)) | PORTCFG_CLKOUT_OFF_gc;
    SREG=s;
and i am trying to generate timer0 interrupt every 500ms as
uint8_t s;
    s = SREG;
    cli();
    Timer_0_Disable(&TCC0);
    //TCC0.CTRLA=(TCC0.CTRLA & (~TC0_CLKSEL_gm)) | TC_CLKSEL_DIV1_gc;
    TCC0.CTRLA=(TCC0.CTRLA & (~TC0_CLKSEL_gm)) | TC_CLKSEL_DIV256_gc;
    //TCC0.CTRLA = TC_CLKSEL_DIV1_gc;
    TCC0.CTRLB=(0<<TC0_CCDEN_bp) | (0<<TC0_CCCEN_bp) | (0<<TC0_CCBEN_bp) | (0<<TC0_CCAEN_bp) | TC_WGMODE_NORMAL_gc;
    TCF0.CTRLD=TC_EVACT_OFF_gc | TC_EVSEL_OFF_gc;
    TCC0.CTRLE=TC_BYTEM_NORMAL_gc;
    TCC0.INTCTRLA=TC_ERRINTLVL_OFF_gc | TC_OVFINTLVL_LO_gc;
    TCC0.INTCTRLB = TC_CCDINTLVL_OFF_gc | TC_CCCINTLVL_OFF_gc | TC_CCBINTLVL_OFF_gc | TC_CCAINTLVL_OFF_gc;
    HIRESF.CTRLA &= ~HIRES_HREN0_bm;
    // Clear the interrupt flags
    TCC0.INTFLAGS=TCF0.INTFLAGS;
    // Set Counter register
    TCC0.CNT=0x0000;
    // Set Period register
    TCC0.PER=0x7A11;//500 ms
    // Set channel A Compare/Capture register
    TCC0.CCA=0x0000;
    // Set channel B Compare/Capture register
    TCC0.CCB=0x0000;
    // Set channel C Compare/Capture register
    TCC0.CCC=0x0000;
    // Set channel D Compare/Capture register
    TCC0.CCD=0x0000;
    SREG=s;
this code is work fine using codevisionAVR but in atmel studio7 the timer take more than 500ms to generate the interrupt have any suggestion please!
  • \$\begingroup\$ What means "more than 500ms" ? Please be a little bit exactlier. \$\endgroup\$
    – Mike
    Commented Nov 14, 2019 at 9:19
  • \$\begingroup\$ it generate the interrupt every 4 seconds, in atmel studio simulator, i notice that the (RC2MEN) bit in OSC.CTRL register always set to 1 even i cleared it \$\endgroup\$ Commented Nov 14, 2019 at 9:29
  • \$\begingroup\$ check oscillator frequency. \$\endgroup\$
    – Mike
    Commented Nov 14, 2019 at 9:36
  • \$\begingroup\$ the same code work fine in codevision AVR at the same board \$\endgroup\$ Commented Nov 14, 2019 at 10:17
the problem was solved the compiler was output the following warning
# warning "Compiler optimizations disabled; functions from <util/delay.h> won't work as designed"
so when i set the optimization level to any optimization level the oscilloscope give me the 500ms timer-interrupt
