Following up on this question I redesigned my circuit with the suggestions from the comments (see comments from @Andy_aka). I want to drive the output of the opamp between 0-24V with an Vin = 0-10V. I also need to draw currents arround 50mA. At low input voltages the power consumption of the opamp would probably damage the device. With a voltage follower I want to draw the current directly from my power source. I found some circuits on the internet and tried implementing them into my design
The voltages seem to be correct for the base and the load (R3). The current from the base is still higher than the current on the load. Should the main draw not come directly from the power source and not the output from the opamp?
UPDATE: I switched the direction of the transistor per @James suggestion and the current in the base is greatly reduced, where the Emitter (load) side draws the current from the collector. I also redraw the result window
