I have a verilog module that contains an FSM.
I have extracted parts of it for this post below.
ISE XST issues warning that all the FF associated with the reg variables shown are removed and I don't understand why.
Any insights please
One of the warnings: Xst:1710 - FF/Latch (without init value) has a constant value of 0 in block . This FF/Latch will be trimmed during the optimization process.
If you look below - bit 3 of RedRam_Data3 is clearly set.
reg [7:0] RedRam_Data1, RedRam_Data1_next, RedRam_Data2, RedRam_Data2_next,
RedRam_Data3, RedRam_Data3_next, RedRam_Data4, RedRam_Data4_next;
reg [5:0] Stream1_Counter, Stream2_Counter, Stream3_Counter, Stream4_Counter;
reg [6:0] Stream1_Counter_next, Stream2_Counter_next, Stream3_Counter_next,
Stream4_Counter_next;
localparam Bit_1_Compare_Value = 6'd14;
always @(posedge clk)
begin
RedRam_Data1 <= RedRam_Data1_next;
RedRam_Data2 <= RedRam_Data2_next;
RedRam_Data3 <= RedRam_Data3_next;
RedRam_Data4 <= RedRam_Data4_next;
Stream1_Counter <= Stream1_Counter_next[5:0];
Stream2_Counter <= Stream2_Counter_next[5:0];
Stream3_Counter <= Stream3_Counter_next[5:0];
Stream4_Counter <= Stream4_Counter_next[5:0];
end
always @*
begin
Stream1_Counter_next = Stream1_Counter;
Stream2_Counter_next = Stream2_Counter;
Stream3_Counter_next = Stream3_Counter;
Stream4_Counter_next = Stream4_Counter;
if(Diff1_Q)
Stream1_Counter_next = Stream1_Counter + 1;
if(Diff2_Q)
Stream1_Counter_next = Stream2_Counter + 1;
if(Diff3_Q)
Stream1_Counter_next = Stream3_Counter + 1;
if(Diff4_Q)
Stream1_Counter_next = Stream4_Counter + 1;
RedRam_Data1_next = RedRam_Data1;
RedRam_Data2_next = RedRam_Data2;
RedRam_Data3_next = RedRam_Data3;
RedRam_Data4_next = RedRam_Data4;
case(FSM_State)
SomeState:
begin
if(Stream1_Counter > Bit_1_Compare_Value)
begin
case(Which_Bit)
0: RedRam_Data1_next[7] = 1'b1;
1: RedRam_Data1_next[6] = 1'b1;
2: RedRam_Data1_next[5] = 1'b1;
3: RedRam_Data1_next[4] = 1'b1;
4: RedRam_Data1_next[3] = 1'b1;
endcase
end // #7
if(Stream2_Counter > Bit_1_Compare_Value)
begin
case(Which_Bit)
0: RedRam_Data2_next[7] = 1'b1;
1: RedRam_Data2_next[6] = 1'b1;
2: RedRam_Data2_next[5] = 1'b1;
3: RedRam_Data2_next[4] = 1'b1;
4: RedRam_Data2_next[3] = 1'b1;
endcase
end // #7
if(Stream3_Counter > Bit_1_Compare_Value)
begin
case(Which_Bit)
0: RedRam_Data3_next[7] = 1'b1;
1: RedRam_Data3_next[6] = 1'b1;
2: RedRam_Data3_next[5] = 1'b1;
3: RedRam_Data3_next[4] = 1'b1;
4: RedRam_Data3_next[3] = 1'b1;
endcase
end // #7
if(Stream4_Counter > Bit_1_Compare_Value)
begin // #7
case(Which_Bit)
0: RedRam_Data4_next[7] = 1'b1;
1: RedRam_Data4_next[6] = 1'b1;
2: RedRam_Data4_next[5] = 1'b1;
3: RedRam_Data4_next[4] = 1'b1;
4: RedRam_Data4_next[3] = 1'b1;
endcase
end // #7
