I would like to use solid polymer electrolytics for decoupling in my designs instead of standard electrolytics for their longer lifespan and substantially lower ESR for marginally increased cost
When choosing decoupling capacitors its frequently mentioned that the lower ESR has a greater tendency to cause ringing so its advised to use medium/high ESR capacitors.
How would a circuit/PCB be designed to avoid power supply ringing with Low ESR capacitors without artificially adding ESR with series resistor as this defeats the purpose of using low ESR parts?
Very low ESR ceramic decoupling caps close to the load is standard practice, how is ringing not an issue there?
