Let us say I have 2 modules. First module gives a differential signal output on a pair of wires while the second module takes the differential signal input.
When I connect the differential signal wires between the modules do I need to connect the GNDs of the two modules together also?
    \$\begingroup\$ That depends on the common mode rating of the components. \$\endgroup\$
    – Jeroen3
    Commented Aug 31, 2020 at 13:04
  • \$\begingroup\$ What modules would they be? \$\endgroup\$
    – Justme
    Commented Aug 31, 2020 at 13:11
  • \$\begingroup\$ @Justme I am just assuming any hypothetical modules.. let us say a DAC differential output and a op-amp based differential input amplifier. \$\endgroup\$
    – scico111
    Commented Aug 31, 2020 at 13:12
  • \$\begingroup\$ @scico111 Well obviously the question cannot be answered for any hypotetical module. It depends on the module! \$\endgroup\$
    – Justme
    Commented Aug 31, 2020 at 13:22
In general, yes you do need to connect a common ground between these modules.
The receiver hardware on the 'input' module will have a 'maximum common-mode' voltage spec for its inputs which you need to ensure is not exceeded, and this voltage is measured with reference to ground.
Of you don't connect Ground between the 2 modules you don't know what this common-mode voltage will be potentially resulting in the receiving module incorrectly interpreting the differential signal and/or suffering some damage.
  • \$\begingroup\$ Does it mean any noise on the Ground connection will be transferred between the modules? If 'yes' then it will defeat our purpose of differential signalling. Pls correct me if I am wrong here. \$\endgroup\$
    – scico111
    Commented Aug 31, 2020 at 13:15
    \$\begingroup\$ Any 'noise on the ground connection' will be common- mode noise. Your receiver will have a common-mode rejection spec probably -90dB or better - so this noise will be ignored. \$\endgroup\$
    – brhans
    Commented Aug 31, 2020 at 13:21
