I have the following schematic as the verification and validation setup for our DC-DC converter:
The idea is that by using a DAC, we can manipulate the output voltage. We plan to send commands to the DAC through I2C, using an Arduino. Therefore, the GND of the PC or laptop should be connected through the GND of the power supply.
Next, we want to involve a load in the circuit by using a MOSFET. The gate of the MOSFET will be connected to a signal generator. We will use this signal to trigger the oscilloscope to observe the effect of the load on the output voltage.
My question is: considering there will be three different GNDs (the first one from the PC or laptop through the Arduino, the second one from the signal generator, and the third one from the power supply), at some point, I need to connect these three GNDs together. Is there any potential issue when doing so, considering there might be a slight potential difference between these three GNDs?
Regards
