That depends very highly on the specific conditions or application you look at. I don't know of any general rule of how to interpret these statistical parameters in regard to electrical measurements, you really need context to do this.
I can only give you one example from my area of work:
When you measure the sEMG (very small voltages on the surface of your skin due to electrical activity of the muscles beneath) you typically would calculate statistical parameters of these highly indeterministic signals. Classical techniques often only determine the mean value of the EMG to estimate the corresponding strength of muscle contraction. More modern approaches try to extract more information out of the signal by calculating additional parameters with a whole set of electrodes.
It was shown that the Kurtosis also corresponds to the strength of muscle contraction [1] and can be used as an additional feature for doing pattern recognition to determine the movement the patient is doing.
However it is questionable how useful this really is, because redunancy to the mere mean or RMS value is pretty high and the Kurtosis does not yield a lot of additional information from the raw EMG signal.
This is the only application of calculating the Kurtosis on electrical quantities like the voltage I ever encountered. But I think this is actually quite an interesting question and maybe other people can share more examples.
[1]: S. Krishnan, R. Akash, D. Kumar, et al., “Finger movement pattern recognition from surface EMG signals using machine learning algorithms,” in Proceedings of the International Conference on Translational Medicine and Imaging 2017, B. Gulyás, P. Padmanabhan, A. Fred, et al., Hrsg. Singapore: Springer, 2019, Kap. 7, p. 75–89.
