Edit: Everyone switch ON for good reading
And the output is the green leds of each protoboard, 2bits for each protoboard, and with those bits, I have to do a "AND" or "OR" so, to do that, 1 bit of my switch is connected to a NOT, in order to send voltaje to the 7432 or 7408, depends on that bit... The AND is working perfectly, but the OR isn´t
Green cable, input for 7432(Not working as expected) Yellow cable, input for 7408(Works fine) Blue cables, output of each result Large Yellow/Orage cable voltaje to each logic gate
So, on the 7432 I have a input of 0´s(from the green bits) and the output is 1, as far as I understand, this is sendind 0´s, so the output should be 0, but only if I connect ground directly outputs the correct bit.
Status input: 0-0 / 0-0 excpected output: 0-0
red led indicates which logic gate is on I add a NOT that is not connected, since this emulator do not recreate the logic gate, this NOT is the one who allow the "AND" or "OR" to turn on(Large Yello and Orange cables or the red LED)
