This is the circuit:
My question is: how can I send signals to the high-side MOSFET driver?
I thought about this way:
But "B" may be 0 V when the MOSFET is on, resulting in a negative voltage on the driver's input (assuming the input's ground is high voltage)
Am I right? If I'm right, how can I drive the high-side driver properly?
EDIT:
What do you guys think about this way (added in green - resistor voltage divider and a fast diode), will it work?
How do they do it in their ICs? Isn't it called "level shifting"?
