I have a PCB which I am trying to connect to a Raspberry Pi. The PCB has some LEDs which indicate some status. Each LED anode is connected to 3.3 V while its cathode goes through a resistor to ground.
I have soldered some wires to the negative side of the LEDs, as that was the only accessible point I could safely solder something to. However, this means that on that point, when the LED is emitting, I get 1.5 V more or less, and when its not emitting, I get 3.3 V.
I have tried to read those values directly in the Raspberry, hoping it was low enough to consider it a logic LOW but it's not.
How could I convert an LED voltage of LIT=3.3 V and OFF=1.5 V to corresponding logic voltages of 3.3 V and 0 V?
My circuit will be similar to this. The control can be 0 V or 3.3 V, depending on some logic or an IC on the PCB I am trying to connect to the Pi.
