I'm confused why this equation is called as plane wave equation. Is that because the direction is constant and indicates it to propagate in only one direction?
Thanks for any comment
First of all, that is not an equation, but it is a way of expressing a plane wave in mathematical form.
In fact the equal sign there doesn't mean "equality", but "equal by definition". You don't solve it, it simply tells you that the lhs (a general expression for the electric field) is equal to the rhs in the case of a plane wave. In other words, that's the mathematical definition of a plane wave.
It is called "plane" because the value of \$ |E| \$ doesn't depend on R, but only on the phase, which is the same for all points in the same plane. That is the plane for which the scalar product \$ \hat k \cdot R \$ is constant, which is perpendicular to the vector \$\hat k\$ (which lies in the direction of propagation).
BTW, note that that expression technically is the phasor of the electric field, because there is no time dependency.
You may want to see, for example, this site.
or the congruence symbol (those are the most common I've seen)
Commented
May 5, 2023 at 21:57
It's called a "plane" wave because it's the equation for a wave that is, well, planar. It's planar in that the values of the wave only vary in time, and in the direction of propagation -- in the two directions perpendicular to the direction of propagation (the plane), all the values are the same. This also means that at any point in space, the direction of propagation is constant.
Contrast this to a spherical wave, where the energy propagates from a point, so the direction of propagation changes from point to point.
Note that when you're introduced to electrodynamics, they just teach you the plane wave. They save spherical propagation for later, after you thoroughly understand propagation in a plane.
