I am tinkering with logic gates preparing for an exam and came across a question that states the following
Construct a common bus system for six registers where each register has five bits.
the expression I got from the truth table was
S2'S1'S0'D0 + S2'S1'S0D1 + S2'S1S0'D2 + S2'S1S0D3 + S2S1'S0'D4
where ' is the complement
the circuit that I constructed looks like
5to1Mux
Assuming the design is right, my question is that I have 6 registers and this design relies on one of the (D0-D4) being 1 and the rest is not important. How can this be used to reference 6 registers? What am I missing because I can't grasp the idea behind it?
The registers and their bits
  • first 10000
  • second 01000
  • third 00100
  • fourth 00010
  • fifth 00001
As far as I can tell there is not sixth register with only one bit being 1
  • bottom input bit is the enable
  • top three bits are the selectors
  • left 5 bits are the register bits
  • \$\begingroup\$ Observations: 1) buses have multiple participants, I expect multiple signal sources for a single line (or pair of lines) in at least one direction. 2) registers have inputs, too. 3) six registers, not five. \$\endgroup\$
    – greybeard
    Commented Jun 8, 2023 at 20:31
Here is how I interpret the exam question. You want the bus to select 1 of the 6 registers. Conceptually, this is a 6:1 mux, where the mux output is a 5-bit data bus. There are 6 data inputs to the mux, each of which is 5 bits wide. You have 6 5-bit registers, for a total of 30 register bits.
The 6:1 mux requires 3 select bits, as you have chosen.
The diagram you created represents one data bit from each of 5 registers. D0 is from the 1st register, D1 is from the 2nd, ... D4 is from the 5th. Now you need to add a 6th term: S2S1'S0D5. Your OR gate needs a 6th input, and you need to add a 6th AND gate for D5.
S2'S1'S0'D0 + S2'S1'S0D1 + S2'S1S0'D2 + S2'S1S0D3 + S2S1'S0'D4 + S2S1'S0D5
To handle all 5 bits of the output, you need to replicate your diagram 5 times.
Since you have 6 registers, you need D5 to be a bit from the 6th register.
  • \$\begingroup\$ but if I add D5 this would result in a 6-bit register which does not match the question description of 5-bit register \$\endgroup\$ Commented Jun 8, 2023 at 20:54
    \$\begingroup\$ @WeedCookie: Re-read my answer carefully. D5 is not a 6-bit register. D5 is one bit in the 6th register. You have a total of 30 data bits: 5 bits each in 6 registers. D0, D1, etc. are bits in different registers. \$\endgroup\$
    – toolic
    Commented Jun 8, 2023 at 20:58
  • \$\begingroup\$ If I understood your explaination correctly this means that I have to follow these equations Number of multiplexers needed = Number of bits in each register Number of inputs in each multiplexers needed = Total Number of registers. resulting in 5 multiplexers each having 6 inputs and a common bus that has 5 output lines, right? \$\endgroup\$ Commented Jun 8, 2023 at 21:06
  • \$\begingroup\$ @WeedCookie; Yes! Exactly! \$\endgroup\$
    – toolic
    Commented Jun 8, 2023 at 21:09
