I was playing around with transistors and stumbled upon something I dont understand. I have the following circuit below:
Where the NMOS used has a threshold voltage of 5V. This means there will be no connection between drain and source if the gate is connected to ground. I thought this meant the voltage at the source side still would be zero if you switch the drain voltage from 0V to 5V. But when I do this:
The potential at the source side also changes to 5V.
Why does the potential change even though the source side has no connection to the drain?
