I am building a custom panel. My output DIN terminals are supposed to be in this order: Power, Ground, Power, Ground, Power, Ground.... I cannot find a proper way (jumpers or bars) to connect them. Only solution I can come up with is using jumper wires which is very sketchy. What is a good practice to connect such terminals together? (I decided not to use the rails as ground as they are connected to Earth ground and I have multiple isolated circuits, got multiple solenoid loaded circuits.)
Thank you!
Update: I found these bridges on Amazon:
Turns out you can remove any screw you want, so I created my custom order jumper. Since I needed multiple of these, I connected them together using ring terminals, and it worked like a charm. Thank you to everyone who helped!
