I am having a problem where there's an area (line) that appears only while running traces and on the draftsman document. the ghost line/region does not show up on any of the layers, I toggled all the layers and navigated through all of them and it does show up.
The region is keeping me from routing through regardless of the layer I'm routing through it.
It's not a component or a trace as I tried the find similar objects for both.
Bottom Layer
  • \$\begingroup\$ Have you also enabled the Keep-Out Layers? \$\endgroup\$
    – Tom L.
    Commented Dec 15, 2023 at 19:45
  • \$\begingroup\$ This link will take you, even without a valid license, to an excellent (and official) Altium forum: forum.live.altium.com (where all you need to do is register for an account). \$\endgroup\$ Commented Dec 15, 2023 at 20:31
  • \$\begingroup\$ as per @ChrisKnudsen ... here is a clickable link forum.live.altium.com ... Chris, if you add https:// then link becomes clickable \$\endgroup\$
    – jsotola
    Commented Dec 15, 2023 at 21:28
It was a very small board cutout. it could only be selected by selecting all. after only showing the board outline view and Ctrl+A and only selecting "Regions" I was able to delete it and then redefine the cutouts.
