I have a LTspice design issue where I encounter the same problem, even when I use other available simulations.
Whenever I increase the load, there is a significant drop in voltage, despite having considered the current requirements in my design.
Here's what I'm attempting to simulate: Vin = 5 V, Vout = 3.3 V for a maximum current of 8A at a frequency of 550 kHz.
The simulation works well when the load is less than 300 mA. However, when I set the load to 0.8 Ω to draw a current of around 4.5 A, I only get 1.5 V instead of the expected 3.3 V at the output. I tried to place a diode instead of the lower switch, but nothing changed. Please advise.
