I'm starting to study VHDL out of personal curiosity, and I'm doing various exercises from a workbook alongside the theory.
However, I’ve come across a solved exercise that raises some doubts for me:
From book: Free Range VHDL of Fabrizio & Bryan Mealy
library IEEE;
use IEEE.std_logic_1164.all;
-- entity
entity my_fsm1 is
port (
TOG_EN : in std_logic;
CLK, CLR : in std_logic;
Z1 : out std_logic
end my_fsm1;
-- architecture
architecture fsm1 of my_fsm1 is
type state_type is (ST0, ST1);
signal PS, NS : state_type;
begin
sync_proc: process(CLK, CLR)
begin
-- take care of the asynchronous input
if (CLR = '1') then
PS <= ST0;
elsif (rising_edge(CLK)) then
PS <= NS;
end if;
end process sync_proc;
comb_proc: process(PS, TOG_EN)
begin
Z1 <= '0'; -- pre-assign output
case PS is
when ST0 => -- items regarding state ST0
Z1 <= '0'; -- Moore output
if (TOG_EN = '1') then
NS <= ST1;
else
NS <= ST0;
end if;
when ST1 => -- items regarding state ST1
Z1 <= '1'; -- Moore output
NS <= ST0;
else
NS <= ST1;
end if;
when others => -- the catch-all condition
Z1 <= '0'; -- arbitrary; it should never
NS <= ST0; -- make it to these two statements
end case;
end process comb_proc;
end fsm1;
I have two questions, and despite thinking about them for a while, I can’t understand them on my own.
- I don’t understand the part where it says
if (CLR = '1') then
PS <= ST0;
PS <= NS;
end if;
Why is there no catch-all condition? I understand that if I used else instead of elsif (mean)
if (CLR = '1') then
PS <= ST0;
else
PS <= NS;
end if;
it would change the logic and is not ok, as I need an activation "IF" the clock rises. However, I read that avoiding a catch-all can lead the synthesized circuit to infer memory and often causes unexpected behaviors. So why not add something like:
if (CLR = '1') then
PS <= ST0;
PS <= NS;
else
PS<= PS;
end if;
In fact, further down, in another if case, the author uses else to "close" and catch all:
NS <= ST1;
else
NS <= ST0;
- If I wanted to include a catch-all, how should I do it? Is it correct to write
else PS <= PS;
or is it better to write
else PS <= PS
NS <= NS;
and could you help me understand why is better PS <= PS
or else PS <= PS + NS <= NS
because I'm not sure which is better?
I’m not entirely clear on this ambivalence for this finite state machine.
[EDIT] @LordTeddy
Thank you very much for your kind response. What you explained was indeed clear to me; my problem was actually only related to the catch-all, which is something that confuses me a lot.
NS <= ST1;
else
NS <= ST0;
I understood that it did not refer to PS, and I was just mentioning it to point out that in this case the if construct had an "else" closure, whereas in the case:
if (CLR = '1') then
PS <= ST0;
PS <= NS;
end if;
not having a catch-all "else" worried me because I had in mind the information from a course I took, where it was said that "avoiding a catch-all can lead the synthesized circuit to infer memory (generating a latch[]), and can cause unexpected behaviors". []in the sense that if the if and elsif conditions are not verified, a latch is created in the synthesis that causes the value to be the previous one.
Unfortunately, this is a note I took, and I don’t have a bibliographic reference for it, so the intent of my question was to infer what the professor meant by this concept, as I don't have much design experience to date.
To clarify the context, he mentioned that in a machine he had created, he forgot to write a catch-all in one of the states of that FSM, which created a latch that prevented the machine from exiting that state. A catch-all would have resolved that issue and is a good practice to put "else" in if statements. However, he didn't provide an example; he only made this assert, which confused me: because now I’m having trouble understanding when I write a finite state machine whether I should close the statement with an "else" in the management of various inputs checked with "if". This is my big doubt.
For example in the exercise book the author write for another FSM:
when S1 =>
CTA <= '0';
if (BUM1 = '0') then
TOUT <= '0';
NS <= S1;
elsif (BUM1 = '1') then
TOUT <= '1';
NS <= S2;
end if;
but I would have put a catch all "else" for what the professor said.
So, this discussion had intrigued me, and every time I see an if, I wonder whether it is useful to use the catch-all "else" or not. That's why I was seeking help from someone knowledgeable on the topic to help me reconstruct the meaning of this phrase.
