We have a working circuit that measures motor phase currents and passes it along to an MCU's internal ADC. This is the circuit: Notice that the output will be 'inverted' , so in software we invert it back to get back the correct value.
We want to replace the above circuit with a Sigma-Delta Modulator such as the AMC1303M0510. Reading through the data sheet , they say that if the differential input is 50mv , that would mean a duty cycle pulses of 89.06 %., The MCU's SDFM module reads these pulses and gives out a value based on the resolution set in software.(As shown in the figure above)
- The 'Differential input' here is referred as (AINN - AINP) OR (AINP - AINN)?
- If voltage at AINN > AINP, does this mean the Duty cycle is between (50 to 89.06)
OR
- If voltage at AINP > AINN, does this mean the Duty cycle is between (50 to 89.06)
Please help clear this confusion. Thankyou!
