I'm designing a State Variable Filter design using switched capacitors to control cut-off and resonance. Simulating this using idealized switches yields excellent results. See attached schematic Filter design with idealized switches
After that I proceeded to replace one of the integrators with a MOSFET version (the center-right part of the circuit). This doesn't work. I'm using a parasitic-insensitive switched cap implementation as you can see. See attached schematic Filter design with 1 integrator using MOSFETS
I tried a couple of implementations for the switches. First of all the parasitic sensitive version, and after that several parasitic-insensitive versions like this one. I've also tried several different NMOS models.
Can anybody tell me what I'm doing wrong here?
  • \$\begingroup\$ Why did you switch it from parasitic sensitive topology to parasitic insensitive topology? Also, you have V+ and V- giving a 24 voltage difference, while your mosfets are driven by only 3 volts. I assume the signal output swings through that range, that would prevent your signal from passing through the mosfet like a switch. \$\endgroup\$
    – horta
    Jun 24, 2014 at 13:54
  • \$\begingroup\$ @horta I switched to parasitic insensitive because the sensitive version changes the integrator response. The filter still works but cutoff is lowered a lot. Indeed the clock signal needs a wider range.. quite logical! \$\endgroup\$ Jun 24, 2014 at 14:46
  • \$\begingroup\$ If the cutoff got lowered, then you probably have your MOSFET gate capacitances to thank for that. Check the model of the MOSFETs you're using and ensure that the gate-drain and gate-source capacitance isn't negatively affecting your filter. \$\endgroup\$
    – horta
    Jun 24, 2014 at 14:58
  • \$\begingroup\$ Add clock waveforms to your post, connect your NMOS Bulk connections properly (to ground), make sure you have NOC (Non-overlapped clocks) - especially the complements, increase voltage swing on gates \$\endgroup\$ Sep 23, 2014 at 10:47
  • \$\begingroup\$ What is the modification? Why don`t you answer our questions? \$\endgroup\$
    – LvW
    Dec 22, 2014 at 17:28
"Can anybody tell me what I'm doing wrong here?"
Yes - I am afraid you didn´t realize that in the second circuit (MOSFET realization) the capacitor C2 now is operated with phase inversion. That means: The most right opamp now is operating as a non-inverting integrator (besides all other effects as mentioned already).
As a result - you have positive feedback, in contrast to the first circuit (with idealized switches and another S/C realization). You can cure the situation by modifying the clock sequence for two switches.
    \$\begingroup\$ Pieter - did you understand my above recommendation? You have produced a phase inversion around C2. \$\endgroup\$
    – LvW
    Sep 23, 2014 at 12:52
