I would like to use an 8-order LPF switched capacitor: MAX7405 datasheet
The cut-off frequency can be set by simply connecting an external oscillator capacitor, Cosc.
I would like to design a 50Hz cut-off frequency but I have doubts on my calculation for the given formula in the datasheet.
max7405 datasheet
Since I want to have a 50Hz fC, I needs the fCLK to be 5000Hz
From the given equation:
fOSC(kHz) = (K * 10^3) / Cosc; Cos in pF , K = 34 for max7405
5000(k) = (34 * 10^3) / ( C * 1pF)
5000 = 34 / ( C * 1pF)
C = 34 / 5nF
C = 6800M
By using the above equation, I calculated an extreme large capacitor with Mega value which is not reasonable.
Am I calculating it in the right way?
  • \$\begingroup\$ should be internal clock \$\endgroup\$
    – jhyap
    Commented Jul 23, 2014 at 7:22
  • \$\begingroup\$ From the description, it says the fc:fclk = 1:100 \$\endgroup\$
    – jhyap
    Commented Jul 23, 2014 at 7:24
For 50 Hz cut-off frequency, you would need fOSC = 5000 Hz = 5 kHz, because it says on the data sheet that, there is a 1:100 ratio from corner frequency (or cut-off frequency) to internal oscillator frequency fOSC. Then the equation requires the numerical value of fOSC in kHz units, which we will use fOSC(kHz) = 5 for this. Then K = 34. Our equation will read as:
fOSC( kHz) = (K * 10^3)/ Cosc; Cosc in pF
5 = (34* 10^3)/ Cosc;
Cosc = 6800 solving this equation.
But remember that this value is given in pF. So this means that Cosc = 6800 pF = 6.8 nF. I think you only had a confusion about the (C*1 pF) part, where you could better write (C/1 pF) for the correct unit conversion.
