I have read How to implement a soft power switch controllable by microcontroller? and am wondering if something similar would be possible with a MAX682.
What I want, is a device that is turned on by pressing a single button, and that turns itself off. I'm using a PIC16F88, but because my battery has 3.6V and I need to drive a 5V LCD, I'm using the MAX682 to step this up.
The problem is that according to the datasheet, the /SHDN pin of the MAX682 should be connected via a resistor to its input voltage. What I would suggest is using its output voltage as an input for /SHDN, like this (only relevant pins are shown):
When the user wants to start the device up, he presses the button to activate the MAX682 and thus the PIC (R1 is required for the MAX682). The PIC is programmed so, that it directly puts high on P1. R2 and R3 form a voltage divider to make 3.6V (I didn't calculate them yet). R4 has then the same function as R1, and makes sure that the MAX682 keeps running. When the PIC wants to shut itself down, it pulls P1 to ground and the MAX682 shuts down.
Would this work, or would the MAX682 have problems if the /SHDN pin isn't connected to IN? And if it would work, could I also remove R4 and connect the 'output' of the voltage divider to the point between SW1 and R1, to save a resistor?
I don't think there is a problem with \$\mathsf{\small \overline{\text{SHDN}}} \$ not being connected to IN, the voltage level just sets the operating frequency based on the current going into the pin.
If you want to get rid of the resistor R4, you will have to calculate the voltage divider resistors such that you get the desired current going into the \$\mathsf{\small \overline{\text{SHDN}}} \$ lead when the microcontroller is on.
Note: there will be a brief time when the switch is activated and the PIC is on, meaning the current going into \$\mathsf{\small \overline{\text{SHDN}}} \$ will double affecting the oscillator frequency because the resistance is cut in half. I don't see an easy way around that. But make sure the calculation of the resistance is such the two frequencies for R and R/2 are both within the range specified in the datasheet (50KHz - 2MHz).
I would add a fairly hefty capacitor (10 µF or more) to the line going from the MAX682 into the Vdd input of the PIC. This will even out any disturbances when the switch is release and the oscillator frequency changes. Also, don't forget 100 nF decoupling caps on all power inputs.
  • \$\begingroup\$ You are right, I was too lazy to add all capacitors to this circuit, but the MAX682 datasheet prescribes 47uF. Good point about the 'double input' time, thanks! \$\endgroup\$
    – user17592
    Oct 19, 2014 at 21:59
  • \$\begingroup\$ On second thought, when we'd remove R4 as suggested, the current going into /SHDN wouldn't be doubled anymore, right? Should I add diodes between the switch and R1 and between the voltage divider and R1, to make sure no current can flow from the battery to the voltage divider or vice versa? \$\endgroup\$
    – user17592
    Oct 20, 2014 at 11:31
  • \$\begingroup\$ @CamilStaps Re the voltage divider resistor values, that's why I said in my answer you would have to recalculate everything. I don't think it matters it comes out exactly the same. I think the diodes are a good idea. \$\endgroup\$
    – tcrosley
    Oct 20, 2014 at 12:03
  • \$\begingroup\$ For reference: I checked this now and it works fine. I used R1=100K, R2=39K, R3=300K (2x150K) which works fine - at least with the 2mA this circuit draws. I used two simple 1N4148's, and I didn't use R4 but applied the voltage divider's output to R1, as discussed. Thanks again! \$\endgroup\$
    – user17592
    Oct 20, 2014 at 17:42
