I have a 96 pole connector and a 32 pole connector on one board which plugs into the mating connectors on another board.
What is the correct way (and hopefully easier way) of ensuring that they are aligned ?
I've dealt with 1 connector in the past and if it was slightly off, it wasn't a big deal because I had space to shift the board so that it aligns. In this case, I can't because if I shift the board up or down, I'm shifting the alignment of two connectors.
What I do, is carefully take measurements and and hope that my measurements are correct.
But maybe there is another way, and maybe an easier way.
I have the following
- Datasheet with measurements
- 3d step model of each connector
- Altium
- I also have access to Solidworks or Autocad (have to check to see which one) but I never use it.
Can I use something from the list that would give me a better sense of security that it's correct rather than just me figuring out lengths ?
