I am doing ground pours on both the top and bottom side of a two-sided board. The top side fill seems to work fine, but the pour on the bottom layer is leaving a bunch of odd shaped blank areas (see image on the left). I haven't routed any traces yet, so the bottom, which has no components, should be a solid blue.
The image on the right has both the top and bottom layers turned on. You can see the slightly darker red areas, that correspond to the blank areas on the bottom. Note these areas don't correspond to any features on the top layer, so it is not a matter of keep out or restrict areas.
I am using Eagle 7.5.0
Anyone know what is causing this?
    \$\begingroup\$ It really looks to me like this design was "cloned" from another design, and that there's something left over on a layer that you aren't looking at that didn't get cleared out and is affecting the pour. Try turning on ALL of the layers and see if anything shows up. \$\endgroup\$
    – Dave Tweed
    Jun 26, 2016 at 11:13
  • \$\begingroup\$ @DaveTweed Actually this was done from scratch as a two-layer board. But I followed your advice, and went into DRC and enabled all layers 1 through 16, and in the Layers tool enabled 2-15 and disabled 1 and 16. All I got was a blank board. \$\endgroup\$
    – tcrosley
    Jun 26, 2016 at 11:19
  • \$\begingroup\$ That's not what I meant. I meant turn on the visibility of ALL of the control layers in the editor. It seems that there's something on a layer you don't normally look at that's creating an issue. \$\endgroup\$
    – Dave Tweed
    Jun 26, 2016 at 11:24
    \$\begingroup\$ You're still not understanding my comment (which Olin has now expanded on). I'm not talking about layers 1-16 (the copper layers). I'm talking about all of the layers >16. \$\endgroup\$
    – Dave Tweed
    Jun 26, 2016 at 11:44
    \$\begingroup\$ @DaveTweed Yes, I did misunderstand. Sorry. Olin's command string revealed the problem, which is something really weird on the bRestrict layer. If I'd followed your instructions correctly, I would have seen it too. \$\endgroup\$
    – tcrosley
    Jun 26, 2016 at 11:51
This really looks like you have something in other layers that is preventing the polygon algorithm from filling the entire area. Obvious suspects are bRestrict and a messed up outlines layer.
The way to find this is to turn on all layers. This is done with DISP ALL, if I remember right. That will show a bunch of superfluous stuff, but it shouldn't be hard to look for edges where there should be none. I'd start with DISP NONE BOT BREST OUT first and examine it carefully.
  • \$\begingroup\$ Thanks, that command string did the trick. I've got some kind of squarish thing in the bRestrict layer, half overlaying my circular board, and half outside it. It doesn't look like anything I recognize, now I just have to get rid of it somehow. Thanks. \$\endgroup\$
    – tcrosley
    Jun 26, 2016 at 11:52
