So, I am trying to build an 8 bit multiplier in verilog. I am using an add/shift method to do it that uses a register. Whenever I run the code, it produces a result that isn't right. My verilog is:
`timescale 1ns / 1ps
module Mul8bit(
input [7:0] Multiplier,
input [7:0] Multiplicand,
input Clock,
output [15:0] led
reg M;
reg [16:0] ACC = 0;
reg start=1;
reg state = 0;
reg [15:0] led;
always @(posedge Clock)
      begin
           led <= ACC[15:0];
      end
    begin
                M = ACC[0];
                case (state)
                    0:
                        if(start)
                        begin
                            begin
                             state = 1;
                             ACC[7:0]<=Multiplier[7:0];
                        end
                    end
                    1,3,5,7,9,11,13,15:
                        begin
                            if(M)
                                begin
                                    ACC[16:8] <= ACC[15:8] + Multiplicand[7:0];   // Add
                                    state <= (state+1); // increase the state
                                end
                            else
                                begin
                                    ACC <= (ACC) >> 1;
                                    state <= (state+2);
                                end
                        end
                    2,4,6,8,10,12,14,16:
                        begin
                            ACC <= (ACC) >> 1;
                            state <= (state+1);
                        end
                    17:
                        begin
                            led <= ACC[15:0];
                            start <= ~start;
                            state <= 0;
                        end
                endcase
Additionally, this is my testbench:
// Company:
// Engineer:
// Create Date: 11/16/2016 08:12:51 PM
// Design Name:
// Module Name: 8bitMultiplier
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module Mul8bit_tb(
    reg [7:0] Multiplier = 8'b10101010;
    reg [7:0] Multiplicand = 8'b00001111;
    reg Clock = 1'b0;
    wire [15:0] led;
    Mul8bit Multi(Multiplier, Multiplicand, Clock, led);
    initial
    begin
    end
    always
    #5
    Clock = ~Clock;
endmodule
So, regardless of whehter the clock keeps going, the program should stop once it enters state 17. However, it continues going and the output is: enter image description here
Is there any clear reason the program doesn't stop once it gets to state 17?
Yes.
Look at your declaration for state and see if it could ever hold the value 17.
  • \$\begingroup\$ What do you mean? It starts at 0 and has to enter the zero case. Depending on whether its odd or even, it enters that case and increments to the next state. So if we are at state 15 and M=1, increment state so that at the next call, we go to state 16. From there we increment by 1 again and we go to 17. \$\endgroup\$ Commented Nov 20, 2016 at 22:08
  • \$\begingroup\$ NVM. i figured it out. So sorry. My bad. Now everything makes sense. \$\endgroup\$ Commented Nov 20, 2016 at 22:12
