enter image description hereThe item measures 1" wide and 1-1/4" high nad about 1/2" front to back
  • 8
    \$\begingroup\$ The pins sticking up very much suggest this is a connector for direct PCB mounting. A look 'into' the barrels might give an insight as what type of connector it is. \$\endgroup\$ – Oldfart Aug 16 '18 at 19:09
    \$\begingroup\$ This is a device to separate punters from their money... :) \$\endgroup\$ – Solar Mike Aug 16 '18 at 19:20
    \$\begingroup\$ Looks high frequency. \$\endgroup\$ – winny Aug 16 '18 at 19:30
    \$\begingroup\$ It's hard to tell - are those 4 little gold pins, inside 4 gold tubes, per side? With nothing but air separating the pins from the tubes, or little mica discs? If so, it is likely a very high frequency (and pricey) RF connector, something like 20GHz. If they are just machined solid pins, then considerably less high-frequency and exotic. \$\endgroup\$ – rdtsc Aug 16 '18 at 19:51
    \$\begingroup\$ Look for "quadrax" connectors, maybe you can find the fit. \$\endgroup\$ – Ale..chenski Aug 16 '18 at 20:30
It looks similar to this Rosenberger HSD Fakra Plug. Maybe missing the plastic portion. You can look at the data sheet here and check measurements.Looks pretty close though. https://rosenberger.de/ok/images/documents/db/D4S21J-40MA5-Y.pdf
