First of all, i must say that I am a software engineer, with very-low to no experience in circuits designs, and a very rudimentary understanding of electrical engineering and circuits. 101 really.
For a software project I am playing with I have built a small physical gauge simulator using some ready-made cheap 7-LED and old needle voltage and amp gauges. They are all powered from a standard DC 24v 3A power supply and I am using a potentiiometer to make the values change manually when i need to change them.
My challenge is the following : Is there a simple way, without special components / devices (NOR MCU arduino/pi to make the gauges "jump" automatically and basically mimic the operation of me fiddling with thee potentiate ? Basically some kind of a DC oscillator - but random jumps are ok.
I do not have an the option (time-wise) to buy special components but I do have a lot of standard ones, ranging from capacitors, to resistors, DC power converters, diodes, LED's, Fuses, transistors (PNP,NPN, mosfet), coils, magnets photoresistors, humidity sensors etc. On the device level I have some low-voltage motors, steppers and solenoids. There is a bit of everything in the very-basic range of stuff.
Is there a simple circuit that can help me achieve this "jump" in the power without any code ? ( funny question for a coder - I know. but there IS a logic behind the project :- )
EDIT I : Here is a picture for better understanding .
EDIT II :
I ended up using a combination of 2 solutions :
A - I took a solenoid that was producing heat and connected it to a relay via and NTC ( PTC would work the same I assume ). The NTC got heaat from the solenoid and functioned like a "gate" for the relay, which also started a small fan to cool the solenoid again. The solenoid operation also made the amp jumps .
B - I Friend brought me an ne555 which I connected to relay. ( but that's an oscillator - which was a few days later )
Although these primitive methods work, I would still like to hear other advice on how to achieve that in some other way .
