The High Common mode Voltage difference op amp AD629 Datasheet on page 12 says that the use of a large sense resistor skews the output. Why is this so? I can't wrap my mind around any other reason than that one side or the other would typically tie to either the source or sink of the power supply.
Is there any advantage of using one of these IC's versus using an instrument amp with input resistor dividers? Would the instrument amp with dividers suffer from the same error?
I am researching an isoamp replacement for an input stage for a galvanic oxygen sensor, which in this case is a small current source converted to voltage by a 2.2k resistor(0-200mv dc). This is a floating voltage other than water contact through the membrane, and I have doubts about whether this would require a 2.2k rComp as explained in the datasheet Figure 36.
