This might be a simple one to answer.
I am using a controller IC (MCP73871) whose load output is connected to an LDO (lm1117Mp3.3). Now according to the datasheet of the MCP73871, I should be adding a capacitor of 4.7uF at the output, while according to lm1117Mp3.3, I need a 10uF capacitor at its input. So is it ok to use both capacitors or just use the one with higher capacity, or it doesn't really matter. Many thanks in advance.
