Assume voltage drop across diode is 0.7V in this case.
From what I understand
When V(input) is positive, but less than 0.7+V OR When V(input) is negative AKA When the diode is acting as open circuit:
V(output) will equal some fraction of V(input), depending on the value of R and the value of the Load Resistance. For example if R=RL, V(output) will equal 1/2 of V(input). And if R is very small compared to RL, V(output) will be approximately equal to V(input). This makes sense to me intuitively.
My confusion arises from the information I've read from varying sources, which all seem to indicate that V(output) will always be equal to V(input), when the diode is acting as an open circuit.
When V(input) is positive, and greater than 0.7+V AKA When the diode acts like a jumper wire
Vo is equal to 0.7+V. This makes sense because Vo is the voltage parallel to 0.7+V.
I tried simulating a circuit like this in falstad, and noticed that Vo will get clipped when Vo>(0.7+V), instead of when Vi>(0.7+V). I also noticed that Vo does not equal Vi when the diode is open circuit, Vo = 1/2Vi (I made the load resistance and the other resistor equal) But every source I've looked to says that Vo will always be equal to Vi AND that Vo will be clipped when Vi tries to go above 0.7+V.
My question is, what am I misunderstanding? Is Vo clipped when Vi is greater than 0.7+V or is Vo clipped when Vo is greater than 0.7+V. Is Vi always equal to Vo? The only situation in which I can think of Vi being equal to Vo for a circuit like this, is when R is small compared to RL, as mentioned earlier.
It would be helpful to put an explicit RL load resistor on that diagram. All that you say is correct, except for the fact that you're confusing the times when RL is absent, or large, or small.
The circuit always clips when Vout > V + 0.7 V.
If RL is absent or very very large, then Vout = Vin, so the same eqaution applies to Vin.
If RL is significant, you need to take account of its voltage divider action with R, before you write clipping conditions for Vin.
  • \$\begingroup\$ Ah I just realised that if RL is absent the circuit is open, so there's no current going through that other resistor and therefore no voltage drop, meaning Vin does in fact equal Vout (when diode is off). This whole time I was thinking that if RL is absent then there's a wire with no resistance where Vout is, which would suggest that Vout=0. I have no idea how I came to that conclusion. So Vin = Vout for the circuit in the image, for any value of R, as long as the diode is off. But if RL is not either absent or a very large number, then Vout will be some fraction of Vin. I think I get it now. \$\endgroup\$
    – boseliker
    Commented May 21, 2020 at 6:17
