I was reading on my lecture slides (I do not put them here since they are not in English) this statement about equivalent baseband channel models:
In typical wireless applications, communication occurs in a passband [fc W/2; fc +W/2] of bandwidth W around a center frequency fc. However, most of the processing, such as coding/decoding, modulation/demodulation, synchronization, etc., is actually done at the baseband. Therefore from a communication system design point of view, it is most useful to have a baseband equivalent representation of the system.
Since
it results:
and
and
I do not understand what it wants to get and why. Precisely:
what does it mean with "equivalent channel model"? I'd say that it means a channel with same input, same output, and same transfer function
which is the equivalent baseband channel model between the last two pictures?
So are baseband signal really used inside a channel?
