The circuit which is shown above has no resistance. So there is no time constant. Plus the current source has no resistance in parallel. So I cant convert it into voltage source. Is there any way to find the voltage across the capacitor after 6 seconds?
1 Answer
Since this appears to be homework we won't give you a direct answer but guide you through it.
- First edit your question to write the equation relating capacitance, charge and voltage.
- Hint: current is the rate of flow of electric charge past a point. What mathematical function can you perform on equation 1 to relate the change in voltage as a function of the current and time?
Edit your post with your work and see if that prompts you enough to complete the task.
\$\begingroup\$ There is no possibility of homework. Because I am not studying in anywhere. I got the answer from the comment. Thanks. \$\endgroup\$ Commented Jun 15, 2020 at 18:44
\$\begingroup\$ \begin{equation} i_c = \frac{dv}{dt} \end{equation} I assume that you are asking for this. \$\endgroup\$ Commented Jun 15, 2020 at 18:47
1\$\begingroup\$ You forgot to add in C making it \$ i_c = C \frac {dv}{dt} \$. I'm glad you figured it out. \$\endgroup\$ Commented Jun 15, 2020 at 18:50
