I am using this LNA in my design and I have an issue with how the devices is being powered.
The turn off/turn On procedure is as following: Apply drain voltage first (5 V) THEN apply gate voltage (3 V)
Turn off procedure is the complete opposite, turn off gate voltage and THEN turn off drain voltage.
Doing it in the wrong order will burn the LNA unfortunately even if there is a microsecond delay between the start up sequence.
Both supplies 5 V and 3 V are coming from separate LDO's.
What options do I have in order to make sure that when I turn on the PCB this procedure will be applied, and vice versa when I disconnect the PCB from main supply.
Simplicity is the biggest factor for me. Is there a single device/IC that can do this in the correct order? Most sequencing devices I have seen like LM3880 would have work if it had dual in dual out. But there is only one supply input on such a device and the LNA requires two different voltage supplies
The design does not have any microcontroller and therefore cannot have any enable pins/switching devices, etc.
