I want to plot a Bode diagram. LTSpice automatically print it in function of frequency. I would like to multiply the frequency for 2*π, in order to obtain the angular frequency.
How can I modify the x-axis quantities?
  • \$\begingroup\$ Can't you just put 2*pi*F instead of F in the x expression box (I'm a microcap user and I know this works). \$\endgroup\$
    Dec 7, 2021 at 16:26
Maybe this is ugly, but it seems to provide the results you want:
The default ac sweep, which gives the result in Hz is commented at the bottom. Also note that the number of steps (100) appears in different places for the two commands.
    \$\begingroup\$ Unfortunately the X-axis for .AC simulations is fixed and cannot be changed. I think this has to do with avoiding the confusion of parametric plots with log axes, and whatnot, but a checkbox to select frequency or pulsation wouldn't have hurt. So @devnull's answer is one way to do it. It will be a tad slower, since it has to calculate the .OP for every iteration. You could also divide the value of C (in this case) by \$2\pi\$, but if you have many states, or delays, you're out of luck. \$\endgroup\$ Dec 7, 2021 at 17:50
