I would like to build a small circuit to measure with my oscilloscope the power emitted by the 5.8GHz video transmitters mounted on my drones. On searching, I found this answer.
The question recommends using a 50 ohm dummy resistive load.
Why was that value chosen? Is it random or can the optimal value be calculated?
Personally I will have to measure signals with power lower than one watt.
To have precise measurements and avoid damaging the video transmitter, is that 50 ohm resistor sufficient, or is a more complex circuit necessary as shown here?
