Is there a circuit that can produce an asymmetric wave, where some parameters of positive and negative half waves are different, such as voltage amplitude or time?
Intuition says that we need a component that acts differently to the positive and negative voltage. A diode does that, but when I test it in a simulator it shows a symmetrical sine wave, so my intuition is wrong ,which means that I don't understand some important aspect of it. The naive view says something like 'in one half wave a x2 inductor is active, and in other half wave a x1 inductor is active.'
Circuit: battery, switch and LCR parallel circuit, where L is doubled and each has a diode facing antiparallel, and one of the L has twice the inductance:
The perfect answer would explain the difference between the naive view and the simulation result and if there are any similar circuits that consist of resistors, inductors (can be coupled), capacitors, diodes that can produce a wave with half waves of positive and negative voltage on a capacitor which are not the same in time or amplitude.
