Question:
Determine the output waveform for the network(assume that all diodes are ideal)
The book says for the positive half-cycle it will be like this:
Similarly I think that for the negative half cycle it will be exactly like this except that the polarity of input voltages are flipped . But book says that the output waveform for the negative half-cycle will be same as positive half-cycle (in the positive region) .
But my intuition tells me that if the polarirites are flipped the output voltage must be in the negative region as current is entering from negative side of V0 .Am I missing something here ?
[I'm not allowed to post more than 2 image links]
