I'm designing a PCB that uses an XMOS XCORE microcontroller (XU316-1024-QF60B-C24) and the only GND connection it presents is the middle ground pad. I couldn't find any example of how this is supposed to be connected, but I'm assuming a via to the ground plane under the chip will be enough.
However, the smallest via I'm allowed to use through my PCB manufacturer is a 0.25mm drill, so the design seems very close to the pads around. Could anyone confirm this is the best approach? And should I add more vias around the pad? Another option, I imagine, could be having a via inside the square. Please see the image below.
XU316-1024-QF60B-C24 datasheet: https://www.xmos.com/download/XU316-1024-QF60B-xcore.ai-Datasheet(3).pdf
