The following is from the book Design of Analog CMOS Integrated Circuit, page 319.
Let's break the loop at the gate of M1.
$$V_{out} = - V_T g_m \biggr[ (R_S + R_F) \parallel R_D\biggr] $$
$$V_F = V_{out} \frac{R_S} {R_F + R_S} $$
$$\Rightarrow \frac{V_F} {V_T} = - \frac{g_m R_S R_D} {R_D + R_S + R_F}$$
$$\Rightarrow L(s) = \frac{V_F} {V_T} = -\frac{g_m R_S R_D} {R_D + R_S + R_F}$$
\$\beta\$ negative since it's negative feedback.
$$V_G = \frac{V_{in} R_F + V_{out} R_S} {R_F + R_S} $$
$$\Rightarrow \beta = -\frac{R_S} {R_S + R_F}$$
$$A_{v, close} = \frac{L} {1 + L} \frac{1} {\beta} = \frac{g_m R_D (R_F + R_S)} {R_D + R_S + R_F - g_m R_D R_S} $$
However, the exact close loop gain is
$$A_{v,close} = \frac{(1 - g_m R_F) R_D} {R_D + R_F + R_S + R_D R_S g_m}$$
You can see how I derive this exact close loop gain from my previous post previous post.
the closed-loop frequency response of a feedback circuit can be expressed without reference to A(s)
$$A_{CL} = \frac{1} {\beta} \frac{L(s)} {1 + L(s)} $$
In conclusion, these two gains are not the same. Is there anything wrong here?
  • \$\begingroup\$ For a negatively feedbacked system, the voltage gain with feedback is given by: Av=A/(1+Aβ), where A is the voltage gain of the amplifier without feedback. \$\endgroup\$ Commented Mar 6 at 9:14
  • \$\begingroup\$ @Franc Can you explain the difference Gain with different method? \$\endgroup\$
    – kile
    Commented Mar 6 at 10:01
  • \$\begingroup\$ Beta is wrong, this is an inverting amplifier, you have the term for a non-inverting one. \$\endgroup\$
    – Designalog
    Commented Mar 6 at 10:29
  • \$\begingroup\$ In the book "Microelectronic circuits" by -Sedra-Smith-, on page 601, there is a BJT polarized in the same way, the study of the reaction should be very similar. However, it is an example found in many student texts. \$\endgroup\$ Commented Mar 6 at 10:30
  • \$\begingroup\$ @kile - you have two different expressions for the closed-loop gain. Both are wrong. The denominator in the 1st one must not show a minus sign - but for Rs=0 it gives the correct gain without negative feedback. And the 2nd one must not show a minus sign in the numerator. More than that, for Rs=0 it does not give the correct gain without feedback. \$\endgroup\$
    – LvW
    Commented Mar 6 at 14:47
When you write the formula in this format, you can easily see that \$ \frac{1}{\beta} \$ should be the ideal closed-loop gain when the loop gain approaches infinity.
$$\frac{1}{\beta} = \lim_{{L \to \infty}} \frac{1}{\beta} \cdot \frac{L(s)}{1 + L(s)}$$
When the loop gain approaches infinity, you can see that \$V_{GS}\$ should be 0, and from that, you can easily derive \$V_{out}/V_{in}\$ and \$\beta\$: $$ \frac{V_{\text{out}}}{V_{\text{in}}} = -\frac{R_{\text{F}}}{R_{\text{S}}} \quad \text{and} \quad \beta = -\frac{R_{\text{S}}}{R_{\text{F}}} $$
You may want to check Middlebrook's feedback theory lectures if you want to learn more about this.
  • \$\begingroup\$ But you mentioned this equation before. $$V_G = \frac{V_{in} R_F + V_{out} R_S} {R_F + R_S} $$ electronics.stackexchange.com/questions/701003/… \$\endgroup\$
    – kile
    Commented Mar 6 at 17:16
    \$\begingroup\$ Yes, that is a simple result obtained by superposition. What you referred to as \$\beta\$ above is the ideal transfer function when the loop gain is infinity, not the feedback factor. \$\endgroup\$
    – internet
    Commented Mar 6 at 17:35
  • \$\begingroup\$ "loop gain approaches infinity, you can see that \$V_{GS}\$ is 0" I don't know why you say \$V_{GS}\$ is 0. Can you explain in more details? \$\endgroup\$
    – kile
    Commented Mar 6 at 17:45
    \$\begingroup\$ Imagine the transistor as an op-amp. If the open-loop gain of the op-amp is infinite, the two inputs become virtually shorted. \$\endgroup\$
    – internet
    Commented Mar 6 at 17:47
  • \$\begingroup\$ Do you mean Gate and Source of this transistor can be seen as two inputs of an op-amp? \$\endgroup\$
    – kile
    Commented Mar 6 at 18:09
@kile: I think, the loop gain calculation L(s) is correct.
However, can you please explain how you arrived at the term Av,close=[L/(1+L)]/beta ?
I rather think, that we always must use the form:
Av,close=af*Ao/(1+L) with loop gain L=Ao * beta and the forward damping factor af.
Added (edit): This forward damping factor (af) gives the input signal at the amplifiers input (gate) when there is no signal coming back from the amplifier output: af=(Rf+Rd)/(Rs+Rf+Rd)
  • \$\begingroup\$ It come from the book Analog Integrated Circuit Design by TONY CHAN CARUSONE (2nd version), Page 221 \$\endgroup\$
    – kile
    Commented Mar 6 at 10:28
  • \$\begingroup\$ The formula is simply the closed-loop gain with an error term duebto finite loop gain. It's most likely part of most loop gain models; I know that part of the asymptotic gain model it is. \$\endgroup\$
    – Designalog
    Commented Mar 6 at 10:32
  • \$\begingroup\$ However, I think his beta term is wrong. \$\endgroup\$
    – Designalog
    Commented Mar 6 at 10:33
  • \$\begingroup\$ @Designalog What's \$\beta\$ according to you? \$\endgroup\$
    – kile
    Commented Mar 6 at 10:41
    \$\begingroup\$ @Designalog $$\beta = -\frac{R_S} {R_F}$$? \$\endgroup\$
    – kile
    Commented Mar 6 at 10:56
