I have a project where I want to make something like a 7-segment display using neon tubes.
Using neon tubes is a hard requirement, so I cannot use LEDs etc.
I do not want to use one 12 ⇒ 5 kV transformer/power supply per segment; since that will get expensive very quickly.
Is there a way of (inexpensively) multiplexing N neon tubes to a single HV supply?
Each segment would use less than 5 watts .
One idea I have had is to use some 240 V opto-TRIACs on the HV side, and a relay (or something) on the 12 V side. Switching the 12 side off, before switching the HV side.
Would that work, or is there a better way?
