I am a bit stuck with the concept of carry-lookahead adder so I'd like to compare it with another concept I'm more familiar with: the ripple-carry adder. I'm trying to make some basic math comparison between the two ones.
Assuming every gate can accept at most 2 (two) inputs and has a delay of '1', and that, at least for the moment, we're adding two 4-bit numbers.
Let's start with the ripple-carry adder. I've built it putting four full-adder in column. Every carry-out is computed as
$$c_i^{(\text{out})} = a_i \cdot b_i + \left[ a_i + b_i \right] \cdot c_i^{(\text{in})} \qquad \text{where} \; \cdot \equiv \text{AND},\, + \equiv \text{OR}$$
Since
$$\left[ a_i + b_i \right]$$
is computed in parallel for every full-adder, the cost for computing the k-th carry-out is
$$1 + 2k$$
right?
Now say we want to compute carry's at first, then the sum -- bit by bit. Using the formula above, (and omitting the superscript) we write that
$$c_{i+1} = g_i + p_i c_i$$
Hence, we can write recursively the fourth term as a function of the first one, i.e.
$$c_1 = g_0 + p_0 c_0 \\ c_2 = g_1 + p_1 g_0 + p_1 p_0 c_0 \\ \vdots \\ c_4 = g_3 + p_3 g_2 + p_3 p_2 g_1 + p_3 p_2 p_1 g_0 + p_3 p_2 p_1 p_0 c_0$$
Of course it is the last term that costs more. How much? I'd say
$$\lceil \log_2{4} \rceil + \lceil \log_2{4} \rceil $$
where the first term is needed for computing every AND operations, while the second one for computing every OR operation.
Hence for an overview ...
$$1 + \lceil \log_2{k} \rceil + 2$$
where the first term is the gate delay needed for computing every propagator/generator term, the second term is the one needed for computing every carry_in, then the last term is the gate delay of a single full-adder.
That is, the comparison of "time" between a ripple-carry adder and a carry-lookahead's one is the comparison of the following two functions
$$1 + 2k$$ $$3 + \lceil \log_2{k} \rceil$$
I know that carry-lookahead can be improved more, and I've done that by myself...though I'd like you give me some feedback about the stuff above for now.
  • \$\begingroup\$ I think your assumption that each port can take 2 inputs does not correspond with reality: a 4 input NAND port would have 2 port delays under your assumption, but in reality it has just 1 port delay, just like a 2 input port. \$\endgroup\$ Commented Dec 15, 2013 at 20:40
  • \$\begingroup\$ @WoutervanOoijen uhm yes!, I would've implemented a 4 input NAND !(abcd) with two NAND's in parallel then a OR gate !(ab) + !(cd), resulting in a 2 port delay. Where am I wrong? \$\endgroup\$ Commented Dec 15, 2013 at 21:32
    \$\begingroup\$ A 4 input NAND is just that: a 4 input NAND, with delay 1. That's (roughly) how the hardware works. \$\endgroup\$ Commented Dec 15, 2013 at 21:48
  • \$\begingroup\$ @WoutervanOoijen Hence, a + b + c + d + e + f can be implemented simply with a 6 input OR, with delay 1? I mean: I should not care about the number of inputs of the gates but instead about the number of gates I have to pass through before the output become stable, right? \$\endgroup\$ Commented Dec 15, 2013 at 22:00
    \$\begingroup\$ The delay through a logic gate as a function of the number of inputs depends greatly on how you are implementing the gate. For an FPGA, logic functions might be implemented using a 4 or 5-input MUX so anything with up to 5 inputs would have the same delay. In an ASIC, the gate delay tends to increase with the number of inputs (all else being equal). \$\endgroup\$
    – Joe Hass
    Commented Dec 15, 2013 at 23:29
