Here is what my textbook has to say about logic levels:
The mapping of a continuous variable onto a discrete binary variable is done by defining logic levels. [...] The first gate is called the driver and the second gate is called the receiver. The output of the driver is connected to the input of the receiver. The driver produces a LOW (0) output in the range of 0 to VOL or a HIGH (1) output in the range of VOH to VDD. If the receiver gets an input in the range of 0 to VIL, it will consider the input to be LOW. If the receiver gets an input in the range of VIH to VDD, it will consider the input to be HIGH. If, for some reason such as noise or faulty components, the receiver’s input should fall in the forbidden zone between VIL and VIH, the behavior of the gate is unpredictable. VOH, VOL, VIH, and VIL are called the output and input high and low logic levels.
(Digital Design and Computer Architecture - David Harris and Sarah Harris)
Since it seems that the driver itself is able to convert continuous analogue values to discrete ones (HIGH and LOW). Why do we need the receiver as well?
Thank you!
