I was looking to find an IC (particularly in the 7400 series) that could act as a very simple RAM device, like a flip-flop or something. I came across 74hc373, but I'm not sure this is what I'm looking for. It seems that the values on all the inputs are held only when latch enable goes from high to low. What I need is something like this, but without the latch enable or clock input requirement, since I would be accessing each bit individually. So, like one input for data and then another for resetting the held data. Does anyone know an IC that could do this? Thanks
P.S. if possible I would like and IC that has eight latches/ram bits (or whatever they would be called), just for the convenience of one byte.
